Threads: 12
Blup !
Now, the only method to check Atari Dump is work
is to re-create a floppy disk with image disk ?
Scp format is not operational in all emulators ?
Thks
Work Together is the better idea to make the futur
You can use Aufit to check the dump and also to convert the dump to a .stx file that can be used in various Atari ST emulators. Unlike the Amiga emulators, none of the Atari ST emulators can use .scp images directly.
Threads: 12
11-30-2014, 07:06 AM
(This post was last modified: 11-30-2014, 07:07 AM by giants.)
Thks.
I prefer to use directly the .scp of course, stx format is... obscurt (like te Dark force
Maybe later we will see this format in emulator.
See you
