Yes, I have run it at 2400 baud using the built-in terminal. Scratch that, I used a terminal program that's on one of my 3.5" external drives. I did test it with the internal terminal, but I think it requires flow control, Xon/Xoff (which is not currently supported). What init string are you using?
(12-31-2017, 05:40 PM)admin Wrote: Yes, I have run it at 2400 baud using the built-in terminal. Scratch that, I used a terminal program that's on one of my 3.5" external drives. I did test it with the internal terminal, but I think it requires flow control, Xon/Xoff (which is not currently supported). What init string are you using?
I'm using "48N1D" right now. Which should turn off XOn/XOff. I did try "48N1E" as well with no success.
The cable that I'm using may be the problem. So I will look at replacing that and see what happens. The cable is really just to change the gender (since my T102 is female port).
