(05-03-2017, 06:01 PM)SomeGuy Wrote: PC-DOS 7.0 uses XDF (1.8mb) format. VirtualBox doesn't support that, nor does any other emulator.
Hi,
Seems my PCDOS 7 disks are normal 1.44's YaY!
But the OS/2 Warp Disks I am working on next do use XDF.
8-(
Regards...GeoKM
ooooOOOOoooo
On the matter of imaging XDF disks like disks 2-15 in OS/2 Warp 3.0, should continue to use IBM 1.44MB mode tracks 0-79?
XDF doesn't make use of extra tracks does it?
8/?
Regards...GeoKM
ooooOOOOoooo
XDF uses only the standard 80 tracks.
I have never encountered a 1.44mb PC-DOS 7.0 1.44m disk set. Are you sure you are not actually using PC-DOS 2000? Confusingly, command.com in PC-DOS 2000 identifies itself as "IBM PC DOS 7.00, revision 1".
Yes, use 1.44MB format for imaging any 3.5" disk that uses a HD floppy disk.
(05-05-2017, 06:51 AM)SomeGuy Wrote: XDF uses only the standard 80 tracks.
Ah Yes, I reckon That is it 8-)
Must be PCDos 2000.
8-)
Thx
Regards...GeoKM
ooooOOOOoooo
