(11-01-2016, 08:12 AM)admin Wrote: You have not setup your router! You need to either use the WPS button on your router (and ATWPS), or set the router's name/password using the AT*SSID command.
Until you have done one of these two things, the router will not ever be found.
ok now i see the router (i write at*ns1 , password and go on to the connection router) and the led is green with write ready , now for connettion to commodore server i write ATDT COMMODORESERVER.COM:1541 and she write that is connected but now the cursor is freexed bloked and i dont write other command is normal???
and for use comet chat what do you do ??? now
please help me i have much program for cometchat but dont work ok bye
Threads: 150
You can't connect to Commodore Server and do anything useful using a terminal program. If you type $ and RETURN after connecting, you will see a list of disks. In order to use the features of Commodore Server you need to use the V1541 disk.
i must work in command mode???? after connecting because the command , the keyboard , dont work in connection ..
ok now i have write $ and see the menu of commodore server but for use it???? and i dont find v1541 ....but i dont understand sorry
Threads: 150
You need to read the information on how to use V1541 on CommodoreServer.com.
(10-09-2016, 04:58 PM)Flack Wrote: Good news, it's fairly simply to send and receive email using telnet:
https://mediatemple.net/community/produc...ing-telnet
Bad news, it's fairly tough to do that with Google/Gmail. I think Gmail requires SSL now, and a lot more handshakes and processes than a simple SMTP/POP connection.
hi, ok i have used the program v 1541 with comet 64 and with the load"cometchat" but i dont understand how to use with wimodem ok :
i connect wi modem (she write ready )
than i connect to the commodore server ( she write connected )
but after i write $ and appair all menu of commodore server i dont know what to do for use this menu ...i cant write load (comet chat or other program )or other please help me or send me a mail of person that can help me thanks very much bye
EmailPMFind
EmailPMFind
ok now i have question : the wimodem is compatibile with contiky or it is possible to use with it ??
Threads: 150
Apparently not. I am not sure what the difference is between telnet and RRnet. I can access any web page, ftp, etc. so I am going to look into this.
Threads: 5
(03-15-2017, 05:31 PM)admin Wrote: Apparently not. I am not sure what the difference is between telnet and RRnet. I can access any web page, ftp, etc. so I am going to look into this.
That would be sweet. RR-Net I believe just refers to the network cards built for the C64. Software designed for it must be looking specifically at the cartridge port and/or specific registers. That's what I gather from
http://wiki.icomp.de/wiki/RR-Net. Would imagine re-writing some of Contiki code would be required. I'm curious however, what are the differences between the User port and the cartridge port? Is there a bandwidth limitation? Is it just different memory space?
