12-16-2015, 10:52 AM
I have made a skeleton SD card setup. I will update this as new versions of the loader (the OSD menu) are made.
Minimal setup SD files
Unzip this archive to the root directory of your SD card. Eject the card from your computer, insert the SD card into the FPGA Arcade Replay board, and power it up. You should see the menu screen (OSD).
From here you can use the cursor keys to move the various options, including loading a core. You will need to keep the cores stored in their own directories.
