ATX soft switch
I have designed a circuit board that plugs into a standard ATX connector from a PC power supply. You plug in your power LED, hard drive LED, reset switch, and power switch into board (see picture). You can turn the power supply on/off and do a reset of the power supply (toggles it off/on) using this board. You can also power a single 12v/5v Molex plug, but most PC power supply have a bunch of those already.
I power my FPGA Arcade Replay board with a micro-ATX case w/built-in power supply using this board.
This will be a product that will be available when the FPGA Arcade Replay boards are available.
Attached Files Thumbnail(s)
(06-20-2014, 09:44 AM)admin Wrote: I have designed a circuit board that plugs into a standard ATX connector from a PC power supply.  You plug in your power LED, hard drive LED, reset switch, and power switch into board (see picture).  You can turn the power supply on/off and do a reset of the power supply (toggles it off/on) using this board.  You can also power a single 12v/5v Molex plug, but most PC power supply have a bunch of those already.
Hi, how this board can obtain Hdd signals (reset ?) from FPGA Arcade since it seems to be connected to it only through a 4 pin molex ?
The on/off switch, reset switch, power LED, and HDD LED pins are connected to the ATX case's on/off switch, reset switch, power LED, and HDD LED. None of these are connected to the Replay board itself.
