02-11-2025, 11:48 AM
That just sets the receiving buffer size. I would expect a larger value to have fewer problems, so this issue has nothing to do with data coming in too fast.
I need to figure out how to create the same setup you have for testing this. Can you describe your exact setup that is required to see this problem? I am guessing that maybe this is a Telnet command or something. Did you try with translation ON? If you are using a Telnet portal for any part of the communication link, then it is very likely that Telnet translation has to be ON.
We could play the game of going backwards in firmware versions until we figured out what change shows this issue. It would be a lot faster if I had a way to re-create this issue.
