Amstrad
#11
These are not flux dumps with SuperCard Pro. Make a SCP image file using SPLICE mode and 2 revolutions. Send it to data @ cbmstuff.com
Have you tried making a copy using SPLICE mode?
#12
Hi,
Just made some tests with my own original disks and all is working fine (up to now); I was using some .DSK with missing data inside....
I will coninue to transfert disks with different protections to be sure .
Thanks for your help Wink
#13
You will be able to duplicate 100% of original disks, using an original disk - or from a SCP image file. Any other type of file format is not flux, and therefore will be missing data.
#14
OK sounds really good !
We just have to re-dump all original disks and replace all those poor .DSK files Big Grin
