recommend irc client? - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem (https://www.cbmstuff.com/forum/forumdisplay.php?fid=75) +--- Thread: recommend irc client? (/showthread.php?tid=956) |
recommend irc client? - prysm1 - 12-31-2022 hi all this has probably been asked before, but my multiple search did not turn up anything. anybody have an irc client they like using on the c64? i am planning to try the c64net irc client, but from the limited response suggest it does not work with the wimodem. Also i was hoping for a client that has color support. regards prysm1 RE: recommend irc client? - admin - 01-02-2023 Anything that works with a real modem will work with the WiModem. I am not aware of any IRC clients for the C64. RE: recommend irc client? - frayedboots - 07-26-2023 I was hoping to give the c64net irc client a go, but early indications are that it is incompatible with the wimodem. I was also hoping to find a client that supports colors. RE: recommend irc client? - admin - 07-27-2023 This program was designed specifically for the ZiModem based WiFi modems. So, it requires that exact configuration, which does not work with a real modem. |
