Synchronet bbs - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=81) +---- Thread: Synchronet bbs (/showthread.php?tid=936) |
Synchronet bbs - jeffdai - 10-10-2022 Love the screen on the modem! Was trying to set my old Synchronet bbs (DOS version not the new windows version). I picked the Hayes modem and set baud to 9600 (same as the modem is set for) and when it trys to initialize it says Invalid result code ATH instead of 0 here is the setup info: DTE Rate 9600 Hardware flow control CTS/RTS Initialization string: AT&F0=0S2=128E0V0X4&C1&D2 Terminal Init String ATE1V1 Dial String ATDT Off hook string ATM0H1 Answer String ATA hang up string ATH Any suggestions appreciated, thanks! RE: Synchronet bbs - admin - 10-10-2022 DON'T use AT&Fxx! That resets the modem to factory defaults and then ignores everything after that! Everything else looks ok. |
