How to convert .tc (Transcopy) or .raw (Kryoflux) to .scp format. - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: PC disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=11) +---- Thread: How to convert .tc (Transcopy) or .raw (Kryoflux) to .scp format. (/showthread.php?tid=905) |
How to convert .tc (Transcopy) or .raw (Kryoflux) to .scp format. - ibmpc5150 - 05-26-2022 How to convert .tc (Transcopy) or .raw (Kryoflux) image to .scp (SuperCard Pro)? It is possible by using PFI.EXE from PCE IBM PC 5150 emulator. http://www.hampa.ch/pub/pce/pre/ *Example 1) TC (Transcopy) --> SCP PFI -p encode pri DISK1.TC DISK1.SCP (.PRI image can be converted to SCP) 2) RAW (Kryoflux) --> SCP PFI track00.0.raw DISK1.SCP *You can change RPM from 360 to 300 or 300 to 360 by using option (set-rpm) PFI DISK1-360RPM.SCP -p set-rpm 300 DISK1-300RPM.SCP PFI DISK1-300RPM.SCP -p set-rpm 360 DISK1-360RPM.SCP *If dumped 2D (360KB) image is from 5.25" 2HD drive (360RPM. 96DPI), you can change 5.25" 2D (300RPM, 48DPI) format by psing PFI.EXE PFI DISK1-360KB-96DPI-360RPM.SCP -p double-step -p set-rpm 300 DISK1-360KB-48DPI-300RPM.SCP RE: How to convert .tc (Transcopy) or .raw (Kryoflux) to .scp format. - admin - 05-30-2022 Nice, thanks for sharing. |
