Kaypro II - Boot Floppy - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Other disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=14) +---- Thread: Kaypro II - Boot Floppy (/showthread.php?tid=835) |
Kaypro II - Boot Floppy - ldkraemer - 06-28-2021 Jim, I've used my Supercard Pro to copy a fresh formatted and rebuilt boot Floppy. The floppy boots fine on my Kaypro II, so I copied it as a CP?m Floppy with my Supercard Pro (using indexed). I then write the *.SCP file back to a fresh floppy and it does not boot on the Kaypro II. I can not attached the scp.zip file because it is too large. How can I get it sent to you? The Floppy Definiitions for the Kaypro II are: BEGIN KAY1 Kaypro II/2 - SSDD 48 tpi 5.25" - 512 x 10 DENSITY MFM LOW CYLINDERS 40 SIDES 1 SECTORS 10 512 SKEW 4 SIDE1 0 0,1,2,3,4,5,6,7,8,9 BSH 3 BLM 7 EXM 0 DSM 194 DRM 63 AL0 0F0H AL1 0 OFS 1 END # KAY1 Kaypro II/2 - SSDD 48 tpi 5.25" - 512 x 10 diskdef kay1 seclen 512 tracks 40 sectrk 10 secbase 0 blocksize 1024 maxdir 64 dirblks 2 skew 1 boottrk 1 os 2.2 end # libdsk data below [kay1] description = KAY1 Kaypro II/2 - SSDD 48 tpi 5.25" - 512 x 10 cylinders = 40 heads = 1 secsize = 512 sectors = 10 secbase = 0 datarate = DD Thanks. Larry RE: Kaypro II - Boot Floppy - admin - 06-28-2021 You can send your image files to data @ cbmstuff.com |
