Cannot get into command by with +++ - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=81) +---- Thread: Cannot get into command by with +++ (/showthread.php?tid=800) |
Cannot get into command by with +++ - wstronks - 02-24-2021 Hi, just connected my WiModem232 to my WiFi. Connecting using Terraterm using Telnet to its IP/port number shows Connected in the OLED screen. Entering +++ in TerraTerm does'nt put me in the command mode. What am I doing wong? Thanks, Wilko RE: Cannot get into command by with +++ - admin - 02-24-2021 You need press all 3 "+" characters in a row within 1 second. If your terminal program has an initialization string that changes the ESCape character (which is normally the "+" character) then you would need to enter whatever that was changed to. |
