Wimodem232 oled case - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: Wimodem232 oled case (/showthread.php?tid=779) |
Wimodem232 oled case - mancity - 12-22-2020 I've been trying to 3d print the case from the download area for my wimodem232 oled, I was able to print the case bottom no problem but the upper case just prints in a huge mess. I've tried it several times with the same result, I am using an Ender 3 pro with a 4mm nozzle, am I doing something wrong or is there an issue with the stl file? Rob. RE: Wimodem232 oled case - admin - 12-22-2020 It prints fine. I printed 4 cases a few days ago with my CR-10. It made me realize that I do need to change the case so that it is held together with screws instead of CA (super-glue). RE: Wimodem232 oled case - mancity - 12-23-2020 (12-22-2020, 04:41 PM)admin Wrote: It prints fine. I printed 4 cases a few days ago with my CR-10. It made me realize that I do need to change the case so that it is held together with screws instead of CA (super-glue). Hi, on checking my printer one of the levelling screws had come loose as well as some of the mounting bolts so I need to sort that out and re-level my printer then I'll try and print it again. Thanks for the reply, knowing the file was okay it got me to check out the printer which I hadn't done in a little while. |
