"Load Image" button not enabled... - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Software (https://www.cbmstuff.com/forum/forumdisplay.php?fid=6) +---- Thread: "Load Image" button not enabled... (/showthread.php?tid=767) |
"Load Image" button not enabled... - geneb - 10-29-2020 I'm unable to load images in the SCP software and I've no idea why: The "Load Image" button is greyed out - the SCP is attached to the system, but no drive is connected to the SCP. Help! tnx. g. RE: "Load Image" button not enabled... - admin - 10-29-2020 LOAD IMAGE is only for creating real disks. If there is no drive connected then you can’t create a real disk! RE: "Load Image" button not enabled... - geneb - 10-29-2020 So how would I go about creating a g64 or d64 file from an SCP image? Having Load Image disabled when the source "device" is a flux image file doesn't make sense. How else are you going to provide an image as the source? Clicking "Start Conversion" doesn't prompt for a file either. g. RE: "Load Image" button not enabled... - admin - 10-29-2020 Click the START CONVERSION button. Only .g64 is supported. .d64 *requires* the flux to be read from an actual disk because this is a "salvage" mode. RE: "Load Image" button not enabled... - geneb - 10-29-2020 Clicking Start Conversion does nothing - unless your saying that that ALSO requires a physical disk. Why would .d64 require a physical disk if you've already got a flux file? Why is "Flux Image" ostensibly a valid Source Device if there's no way to actually specify a flux file? tnx. g. RE: "Load Image" button not enabled... - admin - 10-29-2020 For C64 formats you can only select .g64 to convert from a .scp image. If you select .d64 without a real disk drive in use it won’t respond to starting the conversion. I need to remove that option from the software. You can NOT convert a .scp image to a .d64 image. That *requires* a real disk as that is a salvage mode. This means that the disk is re-read as necessary to recover all sectors. Since there is no way to verify a .g64 image there is no reason to re-read it, so it can be converted from an image. “Flux” is available as an option for several formats. RE: "Load Image" button not enabled... - geneb - 10-30-2020 Ok, thanks. g. RE: "Load Image" button not enabled... - admin - 10-30-2020 Another thing to keep in mind is that with .g64 format you need to have multiple revolutions in order to find the start and end of the track. A single (INDEX) revolution will not work. Same is true for .adf conversions. |
