My Compaqt solution - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Show us your setup! (https://www.cbmstuff.com/forum/forumdisplay.php?fid=44) +---- Thread: My Compaqt solution (/showthread.php?tid=643) |
RE: My Compaqt solution - Vipersan - 08-08-2019 Indeed Jim ..I too was surprised by the green .. but I will probably under-run them all a little. better safe than sorry...and I dont need to read a book by 'em ![]() rgds VS RE: My Compaqt solution - Vipersan - 08-09-2019 Job done ..though I suspect green is still a little over bright..or is it my camera ? lol Anyway ..I read a test DOS floppy and wrote it back without issue.. So all looks good to go. I may just up the green series resistor from 320 ohm to 400 + before I finally get the lid on. Many thanks for all your help Jim. rgds VS RE: My Compaqt solution - admin - 08-09-2019 Neat setup! RE: My Compaqt solution - Vipersan - 08-10-2019 Final photo ..showing the Compaqt SCP in its new home on top of the flatter kryoflux unit...and my old win7 optiplex Floppy station PC . Now to tidy up a little as there is much dust n crap .. not good for floppy disks methinks. oh and if your wondering about the 1541 ..it too is connected by zoom floppy. ![]() rgds VS RE: My Compaqt solution - natevw - 02-05-2020 Thank you Vipersan for sharing this! It looked like such a good match for the SCP and two drives that I decided to re-use your basic plan. From a kind seller on eBay, I bought a very similar DLT setup for hardly more than it must have cost to ship. Pulled out the monster DLT drive, adjusted the rails a bit, and installed the floppy drives. I still need to work out my own mount for the SCP. Worst case I'll make a simple (perhaps translucent) panel and run the USB cable through it, but ideally work out something similar as you did so the plug is useable. I don't think I'll bother with all the LED rework since I never came across an explanation of what they mean, and the app does the blinking for me anyway ![]() RE: My Compaqt solution - Vipersan - 02-26-2020 How is your build going Nate ? Nice to see another Compaqt solution coming together. rgds Evan |
