Still connected after ATZ - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: Still connected after ATZ (/showthread.php?tid=622) |
Still connected after ATZ - brooknet - 04-29-2019 Hi, I'm using a WiModem232 with a Tandy 102 (simple TELCOM app) on the client side. I noticed that after you make a connection with ATDT/ATDP and go back to command mode (with +++), the connection is not dropped on an ATZ. With all modems that I've used, ATZ causes a hang-up but with WiModem232, you can do ATO after an ATZ reset, and it resumes the connection. I wonder, is this intentional? It could be useful for software that repeatedly issues ATZ commands. Thanks, from Lex. P.S. I've enabled notifications now, so I should respond a bit more quickly than I did last time (1-and-a-half months.. sigh..). :-) RE: Still connected after ATZ - admin - 04-29-2019 ATZ does not hang up the modem when in command mode. You need to use ATH. RE: Still connected after ATZ - brooknet - 04-30-2019 (04-29-2019, 11:02 PM)admin Wrote: ATZ does not hang up the modem when in command mode. You need to use ATH. Ah, okay. I'll make sure that I do that. I also use my WiModem232 on an Amstrad PPC640 and that always issues an ATH after quitting the terminal screen - it's only in cases when I'm typing commands manually that I sometimes forget it. Lex. |
