v2.93 firmware notice - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem (https://www.cbmstuff.com/forum/forumdisplay.php?fid=75) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=77) +---- Thread: v2.93 firmware notice (/showthread.php?tid=561) |
v2.93 firmware notice - admin - 08-15-2018 If you recently received a WiModem and you can't get anything to connect, go take a look at the network type using ATI4. If you see the network set as STATIC (and you didn't deliberately do that), you need to enter: AT*NET=DHCP<RETURN> There is a "bug" in the factory defaults that sets the network type to be STATIC instead of DHCP on a reset. I will fix that in the next firmware update. |
