New User - Problems talking to WiModem232 v2 - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=81) +---- Thread: New User - Problems talking to WiModem232 v2 (/showthread.php?tid=536) |
New User - Problems talking to WiModem232 v2 - mike6432 - 06-11-2018 Hi there. I recently picked up the WiModem232 with OLED v2. I have an Apple IIGS ROM1 the WiModem This other cable that I use to connect from my modem port to a USB cable typically for ADTPro - and that works just fine. And I had to pick up this adaptor to change the genders to connect to the WiModem. I have attached some pictures. I'm wondering, is my hardware even correct. I see some talk of a NULL modem cable. I honestly forgot what cable I have but it was just a cheap cable I bought off ebay, but it DOES work when i connect for ADP Pro, unless the wiring inside is different and it's ill-suited for what I'm doing here. I'm using ProTerm 3.1. When I load it up, it wants me to select a modem driver and Port. Well, I choose the Apple Modem 300 (as I understand its only working with 300 baud). I then select the Apple IIGS built in modem port and none of this smart serial business. I input the init code, and I just blow past the printer settings as I don't know why it needs to talk to the printer. What is that for? Anyways, I try to save, use the init settings from here (https://www.cbmstuff.com/forum/showthread.php?tid=477) ProTerm says it's unable to init. I don't know if's the hardware I have or just picking the wrong things via software or both. RE: New User - Problems talking to WiModem232 v2 - admin - 06-11-2018 ADP Pro only works with a NULL modem cable. You need a MODEM cable! That is your problem. RE: New User - Problems talking to WiModem232 v2 - mike6432 - 06-11-2018 (06-11-2018, 12:23 PM)admin Wrote: ADP Pro only works with a NULL modem cable. You need a MODEM cable! That is your problem. Thanks. Crap. Another cable to buy.
RE: New User - Problems talking to WiModem232 v2 - mike6432 - 06-11-2018 Would you be able to point me in the direction to find one for my IIGS and the WiModem? RE: New User - Problems talking to WiModem232 v2 - Kailef - 06-16-2018 (06-11-2018, 12:30 PM)mike6432 Wrote: Would you be able to point me in the direction to find one for my IIGS and the WiModem? This will do the job for you on a //gs. I've got one (Jim actually recommended it to me) and it works perfectly. https://www.monoprice.com/product?p_id=516 Amazingly inexpensive, too. It's only a few dollars and shipping is cheap. They sell the exact same product on Amazon for almost three times as much after shipping. RE: New User - Problems talking to WiModem232 v2 - admin - 06-16-2018 I have the proper cables in stock and will be putting them on the online store. |
