Can‘t init command mode by pressing +++ - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem (https://www.cbmstuff.com/forum/forumdisplay.php?fid=75) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=77) +---- Thread: Can‘t init command mode by pressing +++ (/showthread.php?tid=500) |
Can‘t init command mode by pressing +++ - captain_zzap - 04-07-2018 Title says it all. When I’m connected, I can‘t enter command mode by pressing +++. Anyone else having this problem? RE: Can‘t init command mode by pressing +++ - admin - 04-07-2018 You have to wait one second before pressing the first "+", and each "+" must be pressed within one second of each other. However, the time is adjustable with a S-Register. So, if something changed that time and you saved your settings (AT&W) it may be that it will never work. Also, you can change the character used for "+" to something else. So, again if that was changed and your settings saved, then "+" won't work for entering command mode. I would recommend resetting everything to the defaults using AT&F and then trying +++. RE: Can‘t init command mode by pressing +++ - captain_zzap - 04-21-2018 Reset to default settings worked. Thanks RE: Can‘t init command mode by pressing +++ - admin - 04-21-2018 Quite a few BBS programs automatically change the S-register so that +++ doesn't work. |
