WiModem232 Won't Emergency Reset - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: WiModem232 Won't Emergency Reset (/showthread.php?tid=492) Pages:
1
2
RE: WiModem232 Won't Emergency Reset - admin - 03-24-2018 The code is in C and assembly. The default baud rate of the boot loader is 76800, which is available on Windows if your terminal program supports it. RE: WiModem232 Won't Emergency Reset - Gods - 03-25-2018 (03-24-2018, 09:08 PM)admin Wrote: The code is in C and assembly. The default baud rate of the boot loader is 76800, which is available on Windows if your terminal program supports it. What parts of your code use ASM ? The boot loader (bootrom) baud rate today isn't 74880, with a 26 MHz crystal ? I think the 76800 baud rate is with a 40 MHz crystal and now all ESP8266 units use 26 MHz crystal. Back to the suject, have you see this 115200 serial bug? I tested all the standard serial speeds (until 115K,my serial device don't go higher) and no AT modem answer. RE: WiModem232 Won't Emergency Reset - admin - 03-25-2018 Several parts of the code are in assembly. The boot loader baud is 76800, that is what I have been using during development. What "bug" are you referring to? I have tested up to 230400 baud using a PCI-e serial card. I run my Amiga every day at 115200 baud. RE: WiModem232 Won't Emergency Reset - Gods - 03-25-2018 (03-25-2018, 10:09 AM)admin Wrote: Several parts of the code are in assembly. The boot loader baud is 76800, that is what I have been using during development. You set the serial speed at 115200 baud with at*b115200 and save with at&w. Working until you do a reset with a power cycle. And now the wimodem don't communicate at all. It set a unknown serial speed that isn't a standard rs232 speed (or bad data format). I got garbage characters on screen at all possible speeds. I use the internal COM of motherboard. Tomorrow i test with a usb to serial converter. At 19200 i don't have this issue. RE: WiModem232 Won't Emergency Reset - admin - 03-25-2018 So, it's just 115200 baud that has this issue? Not 19200, 38400, or 57600? I haven't tried saving at 115200. My baud rate is saved as 57600. I switch manually from 57600 to 115200 when I use the Amiga, because I switch device drivers as well. I will try saving the baud rate at 115200 and see what happens. RE: WiModem232 Won't Emergency Reset - Gods - 03-26-2018 (03-25-2018, 07:45 PM)admin Wrote: So, it's just 115200 baud that has this issue? Not 19200, 38400, or 57600? I haven't tried saving at 115200. My baud rate is saved as 57600. I switch manually from 57600 to 115200 when I use the Amiga, because I switch device drivers as well. I will try saving the baud rate at 115200 and see what happens. Tried now at 38400 and 57600 bps , is working. It'is only on 115200 speed. I also used an USB to serial converter (PL-2303 chip) and same results. RE: WiModem232 Won't Emergency Reset - admin - 03-26-2018 OK, I see what the problem is. I will have to re-write the baud rate handler. The save routine doesn't support baud rates higher than 65535 baud. |
