Apple II Super Serial Card (SSC) - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=81) +---- Thread: Apple II Super Serial Card (SSC) (/showthread.php?tid=439) Pages:
1
2
Apple II Super Serial Card (SSC) - c0op3r - 01-05-2018 I am working on making an 'internal WiModem232' to do this I am going to use an Apple SSC and change the connector from female to a male end so that I can connect directly to the SSC card. I want to then put a hood on the connector and use a thick double sided tape to mount that to the card (I am not sure if I am going to mount to front or rear yet). My question is can the WiModem232 be powered by the d25 connector side? If so I count add to pins (assuming that its not already getting a ground) and tap the Apple connector buss for the +5v Cooper RE: Apple II Super Serial Card (SSC) - admin - 01-05-2018 No. There is no power available on any serial port. This why I had to add the external power port. RE: Apple II Super Serial Card (SSC) - c0op3r - 01-05-2018 (01-05-2018, 01:35 PM)admin Wrote: No. There is no power available on any serial port. This why I had to add the external power port. OK I can still work with that, it just would of been a much cleaner install if there was. RE: Apple II Super Serial Card (SSC) - admin - 01-05-2018 Well, there are pins not being used. You could solder a power wire from the USB power input to the unused pin. Do you have the pin out used for your serial card? I could show you where to solder the wire from and to. RE: Apple II Super Serial Card (SSC) - c0op3r - 01-05-2018 (01-05-2018, 03:02 PM)admin Wrote: Well, there are pins not being used. You could solder a power wire from the USB power input to the unused pin. Do you have the pin out used for your serial card? I could show you where to solder the wire from and to. I found this RE: Apple II Super Serial Card (SSC) - admin - 01-05-2018 Ok, we could use pin 13 or 25 (end of top or bottom) connected to a location on the WiModem232. I am at tradeshow and won't be back until Monday, but when I get back I can locate and easy spot to solder the wire to. RE: Apple II Super Serial Card (SSC) - c0op3r - 01-05-2018 (01-05-2018, 04:44 PM)admin Wrote: Ok, we could use pin 13 or 25 (end of top or bottom) connected to a location on the WiModem232. I am at tradeshow and won't be back until Monday, but when I get back I can locate and easy spot to solder the wire to. No rush I just ordered all the parts to make the connection, so there is time. RE: Apple II Super Serial Card (SSC) - Byte Knight - 01-05-2018 Speaking of the SCC, what are your dip switch settings? I can't get the WiModem232 to work with my Platinum IIe... RE: Apple II Super Serial Card (SSC) - c0op3r - 01-05-2018 its in this thread: https://www.cbmstuff.com/forum/showthread.php?tid=419 RE: Apple II Super Serial Card (SSC) - Byte Knight - 01-06-2018 Tried those settings without any luck. What cable are you using? |
