Single-sided drive support? - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Hardware (https://www.cbmstuff.com/forum/forumdisplay.php?fid=42) +---- Thread: Single-sided drive support? (/showthread.php?tid=425) |
Single-sided drive support? - cjreha - 12-25-2017 Hi, new poster here. Is there support for single sided 5.25" drives with the SuperCard Pro? I am using the latest revision software (v1.94) and firmware (v1.2). I ask because I have stacks of "flippy" disks made on Atari 8-bit computers and I plan to image them using a single sided drive, and reading through the manual it seems to only support 360K (double sided) drives. RE: Single-sided drive support? - admin - 12-25-2017 What model disk drive are you using with SuperCard Pro? You might want to use a8rawconv to convert disks to an emulator format and to make actual disks. It's designed to use the SuperCard Pro hardware specifically for Atari 8 bit disks. |
