Adding toggle switch - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: Kickstart Board (https://www.cbmstuff.com/forum/forumdisplay.php?fid=72) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=74) +---- Thread: Adding toggle switch (/showthread.php?tid=421) |
Adding toggle switch - Teevee - 12-21-2017 hello, I just came across this kick board and see that it uses a black and red cable for placing on the pcb. Can a toggle switch be added rather than using the cables? I ask because my Amiga can’t use th soft reboot. Or can turning off the machine or Powering it back up with one of the keys held as stated in the instructions work the same as a soft reboot? RE: Adding toggle switch - admin - 12-21-2017 ALL Amiga's can be soft rebooted by pressing CTRL-AMIGA-AMIGA. You could add a toggle switch, but the entire point to this product is the fact that you can switch Kickstart ROMs by just soft rebooting with certain keys or joystick buttons. You can power up with the key pressed if you wanted to. Any form of reset will work. RE: Adding toggle switch - Teevee - 12-21-2017 Ok that’s good to hear about powering up. I’m still trying to figure out why my Amiga won’t soft reset.. ctrl + Amiga + Amiga doesn’t work. Maybe a short on the reset because I know the actual keys are working Thanks a lot for the info |
