Always Run SCP in Administrator Mode - Avoid Auto Update/Config Issues - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Installation and setup (https://www.cbmstuff.com/forum/forumdisplay.php?fid=5) +---- Thread: Always Run SCP in Administrator Mode - Avoid Auto Update/Config Issues (/showthread.php?tid=42) |
Always Run SCP in Administrator Mode - Avoid Auto Update/Config Issues - sncboom2k - 11-26-2013 With Auto Update support now released - you may encounter an issue with auto-updating your SCP software when using Windows 7 or Windows 8/8.1 This is due to security features built into those operating systems that protect certain types of files in the Program Files and Program Files (x86) folders. You can get around this headache by setting your shortcut to SCP to always run as an Administrator. Follow these steps and ensure you perform this function on the shortcut only. If you perform this on the actual executable file, the setting can be wiped out after the next update. Only perform this function on the shortcut. Step by Step: 1: From your desktop or start menu 2: Right click on the shortcut icon 3: Select Properties from the context menu 4: Select the Compatibility Tab 5: Place a check in "Run this program as an Administrator" 6: Click Apply See attached images for visuals. Now launch SCP from the shortcut and run the update. You should not encounter any issues and the new version should load once the download and update is completed. RE: Always Run SCP in Administrator Mode - Avoid Auto Update Issues - admin - 11-26-2013 Thanks for the detailed info! RE: Always Run SCP in Administrator Mode - Avoid Auto Update Issues - Hanzu - 02-26-2016 In Windows 10 everything above is true but procedure has some differences: Follow these steps and notice it is possible to perform this function on the shortcut only. Step by Step: 1: Navigate to C:\Program Files (x86)\SCP 2: Drag SCP.exe holding SHIFT+CTRL and release it to the Desktop. 3: Right click on the shortcut icon 3: Select Properties from the context menu 4: Select the Shortcut Tab 5: Click Advanced... 5: Place a check in "Run as an Administrator" 6: Click OK, Apply and OK RE: Always Run SCP in Administrator Mode - Avoid Auto Update/Config Issues - admin - 02-26-2016 Using the short-cut works fine for me and others under Windows 10. |
