Drive Speed and Media Test - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Hardware (https://www.cbmstuff.com/forum/forumdisplay.php?fid=42) +----- Forum: Compatible Drives (https://www.cbmstuff.com/forum/forumdisplay.php?fid=43) +----- Thread: Drive Speed and Media Test (/showthread.php?tid=359) |
Drive Speed and Media Test - Markus - 02-01-2017 Hi, I have a Panasonic 475-4 that works well so far but I have also have a 475-2 which appears to work but the copied Disks are blank. Checked Drive Speed and it was 351RPM not 360. Media Test comes up mostly bad whereas on the 475-4 media test is ALL 100%. This is ALL Brand new media including Dysan and tests 100% except on this seemingly malfunctioning Pan. 475-2. Can I adjust the Drive Speed and how? Would that make a difference? RE: Drive Speed and Media Test - admin - 02-02-2017 Sounds like your drive is bad. You can't adjust drive speeds with the 475 series drives. |
