Q-Link - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem (https://www.cbmstuff.com/forum/forumdisplay.php?fid=75) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=77) +---- Thread: Q-Link (/showthread.php?tid=329) |
Q-Link - admin - 09-05-2016 As of v1.2 firmware you can now log into Q-Link by "spoofing" a phone number. Spoofing is where you convert one thing into another. Since Q-Link only accepts numbers (digits) and not letters, there is no way to directly "dial" to the Q-Link server. Instead, we use the new spoofing support to allow an automatic connection. First, you need to enter a spoofing entry. You can have up to 10 phone numbers spoofed. For my setup I entered: AT&SN0=5551212,Q-LINK.NET:5190 <RETURN> This means that whenever there is a ATDT5551212 encountered, the modem will substitute that number with whatever URL : PORT is after the ',' character. So, this case, if you just entered ATDT5551212 it would connect using ATDTQ-LINK.NET:5190 instead of the number. NOTE! Q-Link *requires* that the DCD be set to 'always on', and the max baud rate is 1200. So, before you can use your Q-Link disk you need to make sure DCD is set to on (AT&C0), and the baud rate need to be set to either 300 baud (AT*B300) or 1200 baud (AT*B1200), depending on the modem selection. After you set these, you can permanently store the changes using AT&W if you want. I selected the Commodore 1670 modem, and 1200 baud. |
