Misleading error statement - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Software (https://www.cbmstuff.com/forum/forumdisplay.php?fid=6) +----- Forum: Disk Copier (https://www.cbmstuff.com/forum/forumdisplay.php?fid=38) +----- Thread: Misleading error statement (/showthread.php?tid=301) |
Misleading error statement - dfstudios - 03-16-2016 I've just had a slight issue when trying to load an SCP image into the Disk Archiver where I get an error message that the file type is not recognised. I eventually found out that the cause of the error was because I had inadvertently left the file open in WinUAE. I think a bit more clarity here as to why the file could not be opened instead of the file type is not recognised would be helpful. Kind regards, Francis RE: Misleading error statement - admin - 03-16-2016 That error message is passed in by Windows, I just re-print it in the dialogue box. I guess I can look at doing some type of sanity check. RE: Misleading error statement - dfstudios - 03-17-2016 Thanks, that would really be helpful. I initially thought that the SCP file was corrupt before realising why it was happening. Kind regards, Francis |
