Image file loads as different setting - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Software (https://www.cbmstuff.com/forum/forumdisplay.php?fid=6) +----- Forum: Disk Copier (https://www.cbmstuff.com/forum/forumdisplay.php?fid=38) +----- Thread: Image file loads as different setting (/showthread.php?tid=275) |
Image file loads as different setting - clh333 - 12-21-2015 I am copying some of the older stuff and submitting it to the WinWorld library. They have been patient as I learn the ropes: my thanks and my condolences! I ran across the following issue today and made a note to ask: Re-imaging a particular software title (Lucid 3D from DacEasy) and using a Panasonic 360k drive, I set the copy parameters to IBM360, index sync, wipe tracks. I created an image file, zipped it and sent it off to WW. Then I loaded the image file again and was going to write it back to disk as proof of copy. I noticed as I loaded the file that the IBM360 setting changed automatically to TI/99. When I reset the TI/99 setting to IBM360, the image disappeared and I had to reload it. When I reloaded it, it again came up as TI/99. Somehow this seems counter-intuitive. Does the .scp file contain a "signature" indicating its type, or is the image analyzed on-the-fly as it is loaded? -CH- RE: Image file loads as different setting - admin - 12-21-2015 That is a bug, but it won't matter for creating a disk. The ID is only used for the display. The information about the tracks used and such is contained in the raw data itself. |
