Disk copier doesnt allow target to a flux file with combo drive? - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Software (https://www.cbmstuff.com/forum/forumdisplay.php?fid=6) +---- Thread: Disk copier doesnt allow target to a flux file with combo drive? (/showthread.php?tid=255) |
Disk copier doesnt allow target to a flux file with combo drive? - aphexian - 11-09-2015 Greetings, Been trying out various drives with the supercard pro and I got my hands on a dual combo Epson SD-800 drive. When connected it acts as 2 separate drives and the supercard pro detects them properly as separate drives. My issue is when you go to the disk copier/imager, the target device selection box only allows you to select drive 0 and drive 1 instead of a flux file. Amiga and C64 (my main dumping needs) allow you to select ADF or G64 but still no raw flux file. I clicked reset to defaults and briefly had flux file show back up in the target devices but it vanished again on program restart. Am I doing something wrong or is this just wierdness with this combo drive? Wasnt sure if I should put this in software or hardware since it could go either way. Thanks again for the awesome device, I've been loving it after I put some time into learning the ropes... -aphexian RE: Disk copier doesnt allow target to a flux file with combo drive? - admin - 11-10-2015 This has been reported recently. I will take a look at it today. RE: Disk copier doesnt allow target to a flux file with combo drive? - aphexian - 11-10-2015 (11-10-2015, 09:29 AM)admin Wrote: This has been reported recently. I will take a look at it today. Thanks! Looking forward to seeing this product evolve... -Mitch RE: Disk copier doesnt allow target to a flux file with combo drive? - aphexian - 11-10-2015 (11-10-2015, 01:50 PM)aphexian Wrote:(11-10-2015, 09:29 AM)admin Wrote: This has been reported recently. I will take a look at it today. Just had a play around with v1.90 and it works exactly as I would expect it to now on the Epson combofloppy drive. Thats some amazing turn-around if I dont say so myself! Thanks again! RE: Disk copier doesnt allow target to a flux file with combo drive? - admin - 11-10-2015 Oh good.. yeah, there were some funny cases there when you would switch between disk types. I ended re-writing that part of the code to make it more logical. |
