Ok, So what am I doing wrong?? - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Installation and setup (https://www.cbmstuff.com/forum/forumdisplay.php?fid=5) +---- Thread: Ok, So what am I doing wrong?? (/showthread.php?tid=146) Pages:
1
2
RE: Ok, So what am I doing wrong?? - admin - 07-23-2015 Most people are using dual drives (3.5" and 5.25"). There are no issues using dual drives. However, of you have one of the "flippy modded" drives, you can only use it alone due to the mod that is done. SCP can not determine the type of drive connected, so you could actually copy/image from a 3.5" drive to a 5.25" drive, so make sure your settings are correct. You should be able to copy drive to drive, image from either drive to a flux image, and copy from an image to either drive. |
