Trouble with Kaypro disks - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Other disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=14) +---- Thread: Trouble with Kaypro disks (/showthread.php?tid=1237) |
Trouble with Kaypro disks - Wayback - 12-13-2025 Hey. Been using the SCP for years on my Commodore, but recently wanted to start playing around with my Kaypro. Starting off simple, I wanted to try backing up my Kaypro 2X boot disk to an SCP image, then write it out to a blank. Kind of a proof of concept for me to verify that this thing works for Kaypro disks. Unfortunately I haven't had any success. Perhaps the SCP isn't compatible with Kaypro disks.... I dunno. This is why I'm here. If it doesn't support it, then so be it... but if it should, then could you please provide me with the appropriate settings I should use to backup/restore the disk? Thanks for your time. Wayback RE: Trouble with Kaypro disks - admin - 12-14-2025 Flux is flux, it does not matter what upper level format the disk is using. What disk drive are you using? You should be able to use a simple INDEX mode for imaging and copying. You can always make an image file (using SPLICE mode with 3 revolutions) and send me the image to: data @ cbmstuff.com I can look at the image file and tell you if there is a problem with the drive, power supply, density, etc. |
