WiModem232 OLED LED stopped working - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: WiModem232 OLED LED stopped working (/showthread.php?tid=1230) |
WiModem232 OLED LED stopped working - bbsing - 11-25-2025 Today I was using my WiModem232 and after a at&w the LED went out. I modified a few things prior to the at&w. at*busy=in a call write now call back later ats0=9 at&w that caused the LED to go out. I've tried to set the LED via at*led5, at*led0, at*led1, nothing is bring it back. I did reboot and complete power cycle nothing helped it. I use that LED to see who is trying to login to my system. I don't see anyone else with this issue. firmware: v6.50-01/20/25 RE: WiModem232 OLED LED stopped working - bbsing - 11-25-2025 (11-25-2025, 05:31 PM)bbsing Wrote: Today I was using my WiModem232 and after a at&w the LED went out. After I powered off the WiModem232 for several minutes, and plugged it back in, the LED came back on. RE: WiModem232 OLED LED stopped working - admin - 11-27-2025 Maybe you have a problem with the power source plugged into the WiModem232? RE: WiModem232 OLED LED stopped working - huneffey - 12-11-2025 If the LED went out right after saving the profile, it may be that the stored config now forces a mode where the status LED is suppressed. A factory reset usually brings it back: try AT&F followed by AT&W, then power cycle. If the LED returns, you can reapply your settings one by one to see which command disables it. |
