Compatibility of WiModem232 Pro with Various Commodore 8-bit Systems - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: Compatibility of WiModem232 Pro with Various Commodore 8-bit Systems (/showthread.php?tid=1142) |
Compatibility of WiModem232 Pro with Various Commodore 8-bit Systems - etulantrewarding - 12-04-2024 Hi all, I'm considering getting the WiModem232 Pro for my Commodore 64/128, but I'm curious about its compatibility with other Commodore 8-bit systems, like the VIC-20 or the Plus/4. Has anyone tried using the WiModem232 Pro with these systems? Also, are there any specific setup requirements or limitations that I should be aware of when using it with older models or different configurations? Thanks in advance for your help!
RE: Compatibility of WiModem232 Pro with Various Commodore 8-bit Systems - admin - 12-04-2024 The WiModem232 Pro is not for 8 bit machines (unless you have a RS232 cartridge). You would want the version made specifically for the C64, VIC-20, Plus/4, PET, etc. You can read about that here: https://www.cbmstuff.com/index.php?route=product/product&product_id=58 |
