Run-time error '6' Overflow - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Installation and setup (https://www.cbmstuff.com/forum/forumdisplay.php?fid=5) +---- Thread: Run-time error '6' Overflow (/showthread.php?tid=111) |
Run-time error '6' Overflow - McWulff - 03-29-2014 Hi there, i brought the SuperCardPro and installed it as discribed in the manual/ at the forums. (I installed the software& drivers as administrator, updated the SuperCardPro, copied the dll file in the SysWoW64 directory and registered it as administrator) Now i have a problem to run the software properly. Always when i start the software (as administrator) i get athe following error "Run.time error '6': Overflow". Dosent matter if i have the SuperCardPro connected or not. By the way, the fist time when i started the program, it started correctly, the second time the error occurs... My operating system is Windows 8.1 with latest upgrades. Please help! RE: Run-time error '6' Overflow - admin - 03-29-2014 I have never had this problem reported by anyone before. This occurs when there is a setting beyond the range that is allowed. Try deleting the config file (scp.ini) located in: Local Settings\Application Data\SCP\ or Local Settings\App Data\SCP\ RE: Run-time error '6' Overflow - McWulff - 03-29-2014 Hi, thanks for the hint. Now the software starts normally... |
