CBMSTUFF FORUM
Kit without keyswitches? - Printable Version
+--- Forum: BLINGBOARD64 (https://www.cbmstuff.com/forum/forumdisplay.php?fid=143)
+--- Thread: Kit without keyswitches? (/showthread.php?tid=1095)
Kit without keyswitches? - Marsupial - 05-13-2024
Most mechanical keyboard enthousiasts have preferred key switches, and often these are not the ones included in the perk kits. Why isn't there an option for those who already have their switches in stock?
RE: Kit without keyswitches? - admin - 05-14-2024
Because the only way to make this affordable is to purchase tens of thousands of the same switch. Having different switches means the overall cost of switches goes up.
RE: Kit without keyswitches? - Marsupial - 05-14-2024
Yes... But what about no switches at all for the kit, for those who already have theirs?
I might consider doing that for the retail version, but not for the campaign version.  However, you would be limited to Gateron, Akko, or Cherry brands because those are the only brands that have key switches with the proper size and location hole for the LED (which sits inside of the switch body). Also, only 5 pin switches will work.
