CBMSTUFF FORUM
Keycap Availability - Printable Version
+--- Forum: KEYCAP CAMPAIGN (https://www.cbmstuff.com/forum/forumdisplay.php?fid=128)
+--- Thread: Keycap Availability (/showthread.php?tid=1068)
Pages: 1 2 3 4 5 6
RE: Keycap Availability - tw1l1ght - 05-08-2026
(05-07-2026, 09:34 PM)admin Wrote: Keycaps for the original C64 keybioards are in production  currently.
Thank you!  Smile
RE: Keycap Availability - drj3rk - 05-14-2026
Would these ones work on the Mechboard64 with or without the little adapter pegs, or should I just wait for the originals (which do require the adapters)? All they do is raise the keys up slightly for clearance on the Mechboard. I just want to make sure I get the simplest solution. If these will work on the Mechboard, then I'll just order a set now. Smile
RE: Keycap Availability - admin - 05-14-2026
Keycaps for the Blingboard64 will not work with the Mechboard. The keycaps are designed with different offsets. They will work with Commodore's new C64U and C64CU machines.
Keycaps for the original C64 will work with the Mechboard, using the adapters.
Perfect, thanks for the information!  I'll wait.  Smile
RE: Keycap Availability - gc2318 - 05-19-2026
Hello
i just wanted to mention that i expect there are a few people out there are a little frustrated that the only keycaps that are available are for the blingboard when you your previous messages there was no mention that the latest delivery was keycaps only for the blingboard..
i don't want to criticise your products because you make some fab stuff but in future can you please be more transparent about what is going to be available ?
RE: Keycap Availability - admin - 05-22-2026
It has been no secret that the order of production has been Blingboard64 keycaps before more keycaps for the original computer. The older keycaps are in production.
