Note about yellow wire
It seems that many people are putting the yellow wire on the wrong pin of the two pin connector. Make sure you put the yellow wire inside of the 2nd pin socket, which is NOT connected to ground.
If your machine just resets over and over again when you power it up, the yellow wire is in the wrong position.
