Blank Display
My WiModem232OLED’s display is no longer functioning.
The WiModem232 itself is still working fine. Just no display.
Just blank screen.
Anything I can do?
Thanks.
Return it and I can replace the display. These are glass and pretty fragile, so they can't be dropped.
(11-02-2018, 08:50 AM)admin Wrote: Return it and I can replace the display.  These are glass and pretty fragile, so they can't be dropped.
Hi.
I’ve had it in this (see pic) case since a week after I started using it back in May. About a month ago the display would stop after about an hour of use. So I’d unplug plug it. And wait a while, plug it back in, and then the display would come back on. Throughout this the Wimodem232 would function and still does. Finally a few days ago the display did not come back on. Just wanted to give you the gist of things. Thanks.
Attached Files Thumbnail(s)
Ok, sounds like a faulty display. I have had one on for months without issues, so it's not a normal thing for sure. Just send it back and I will replace it.
Got the address. Will send. Thx. Chris
