No Wifi connecting at poweron, only manuell
hello,
i have a little "problem":
WifiModem232 didnt connecting to my Home Wifi at poweron :-(
I have always to scan WLan and reconfig SSID and to enter PW.
Yes, i store the settings with at&w.
But after poweroff the WifiModem232, this settings are lost ...
Any idea?
regards pcollins
The WiModem always automatically remembers the router SSID and password until you deliberately change it, and you need to only do this one time.  This is something that you don't have to ever save using AT&W.
When you use the AT&W to save other settings, are those settings actually saved?
Do you have any type of firewall in your router?
