(11-05-2016, 05:46 PM)admin Wrote: You need to learn and understand how ASCII and CBM graphics modes work. This is same with all devices - real modems, fake modems, etc. It's a CBM program thing and has nothing to do with the WiModem.
To use the V1541 driver in 38.4Kbps mode, you need to first connect with 2400 baud, switch to 38400 baud, invert the polarities for the handshaking, and load the V1541-38400 driver and use it.
ok now i have connected my c 64 with other bbs page (mad world , avalonisle ,border line , scorp portal wrong number ) and i subscribe it ...now i whant know if there are the bbs page where there are person to chat or there are a chat to use for speack with other person ok thanks bye ( in the previoun time i connect with a person in china but have no timre to speack .....but no orther connection tio chat ) it is possible have other ???
You can use Q-Link, Comet Chat, and a few others.
(11-06-2016, 05:33 PM)admin Wrote: You can use Q-Link, Comet Chat, and a few others.
ok thanks buyt a curiosity if i change my baud to 38400 or other 9600 etc .... when i turn off my c 64 a nd the wi modem the baud return to 2400 ???
Only if you deliberately store the settings (AT&W).
11-10-2016, 11:23 AM
(This post was last modified: 11-10-2016, 11:29 AM by scanword.
Edit Reason: finisc message
hi today i want change baud but do not work :
i connect to 2400 when i use terminal to change to 38400
but i dont know how change the polarities of handscaking because i have two voice : cts and dcd ...but i must change all two ??
and after when i passed to 0 in all two voice i passed in to 38400 baud ...but after i do not is possible write correct caracter .......i dont know how do now .
Please tell me the correct procedure because i think that i do an erroro of procedure ok bye
The DCD polarity can be left alone. You need to invert the CTS polarity, and then handshake polarity. You MUST be using the V1541-38400 driver. No other driver will work.
(11-11-2016, 11:39 AM)admin Wrote: The DCD polarity can be left alone. You need to invert the CTS polarity, and then handshake polarity. You MUST be using the V1541-38400 driver. No other driver will work.
ok i can not use this procedure ....because i write this : at*b1200 or 2400 or 4800 or 38400 ....and after return and write ok
but after i cannot write ....no caracter no possibiliti to write then .......... and now??
You have to load and activate V1541-38400 driver after setting the baud rate and polarities for the 38400 baud driver, using the normal V1541 driver.
HELLO THEN I HAVE LOADED BEFORE V-1541 38 K THEN I HAVE LOADED THE TERMINAL AND HAVE MOVED POLARITIES DCD EL OTHER HANDSCHIP BUT JUST CHANGED IN 38400 PORTEVO NOT WRITE MORE CHARACTERS ON THE TERMINAL PROGRAM THEN I reloaded FILE V 1541 38 K BUT DOES NOT HAVE wRONG THE PROCEDURE WHAT HAPPENS C 'is SOMETHING wRONG?
I think you are confused about what V1541 is! You can't use a terminal program with V1541! The V1541-38400 program is only for using the various Commodore Server programs (like Comet Chat).
For terminal programs, you would have to use 300-9600 baud, with the appropriate terminal driver.
