Garbage Characters
#11
The 8 bit search engine has it:
http://cbm8bit.com/8bit/commodore/search...=ccgms+7.1
There is a version by Fairlight, but I am using the LETHAL version.
Zterm also works very well and has the same features as CCGMS.
http://cbm8bit.com/8bit/commodore/search?query=zterm
#12
(12-03-2016, 08:03 AM)Thanks! I don\t have any way to get it from the website to a floppy disk though. I don't have an SD drive for the C64. I guess it's an investment I'll have to make. admin Wrote: The 8 bit search engine has it:
#13
I get garbage at any baud rate with the Final Cartridge III inserted and active in my NTSC SX-64.
Is this expected? Any idea what the FC3 is doing to interfere?
#14
I would guess this could be power related (faulty C64 power supply).  The FCIII cartridge does draw quite a bit of power.  I have never tried the FCIII with the WiModem (I use a U2+ in the cartridge port).  I will try it and see if this is perhaps a problem with the FCIII interfering with the serial port.
#15
I tested the FCIII and it works fine at all baud rates I tested (1200, 2400, and 9600). So, I would look at your C64's power supply as being the issue.
#16
Cool, thank you. Will look in to (how to do) that!
