Threads: 12
Blup !
Maybe a new option will be good idea for Enter the Number of RETRY when, during DUMP, it don't find INDEX
a option like : Nb Index Retry : 6
Work Together is the better idea to make the futur
The index is ALWAYS found on every revolution. If not, there is a hardware problem.
Threads: 12
(07-07-2014, 12:30 AM)admin Wrote: The index is ALWAYS found on every revolution. If not, there is a hardware problem.
Yes yes, you right
But when a index problem apear, a box a SCP say : Abort Or Retry
So... I think, If I can RETRY it is logic to make a option to choice Nbr a reply
If not, what its the logic to give the choise to retry or quit ?
If it's a H/W probleme and I think Yes at 100%
Maybe, as you give the choice to Retry
it's logic to do this AUTOMATIC for, exemple, 6 times
No ?
You should never, ever see this problem except when there is no disk in the drive. This is something that has to be corrected by the user. There is no way to 'automatically' fix a hardware error.
