Winmodem232 not saving all setting. - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: Winmodem232 not saving all setting. (/showthread.php?tid=963) |
Winmodem232 not saving all setting. - Sniperstorm - 01-22-2023 I just picked up my 2nd Winmodem232. I plugged it into my Atari ST and set it all up. I called out to a few bbs systems with no problems. Whenever I remove power from the unit it will boot back up and will default back to 300 Baud and not see my network or connect to it. Any ideas on what is going on and how to fix it? RE: Winmodem232 not saving all setting. - Sniperstorm - 01-22-2023 I just changed the AT*N back to DHCP and it now connects. But will only come back at 300 baud. RE: Winmodem232 not saving all setting. - admin - 01-23-2023 You have to save the settings after changing them if you want them permanently stored. This is not optional. You have to use AT&W to write the changes permanently. |
