Apple /// System Disks - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Other disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=14) +---- Thread: Apple /// System Disks (/showthread.php?tid=633) |
Apple /// System Disks - abeckett - 07-14-2019 Hi there - I copied successfully a Commodore 64 disk and it worked great in splice mode but failed in index mode. I am guessing that this is normal. I then attempted to copy Apple /// system disks - but no mode worked. I selected Apple //. I am wondering if maybe my drive isn't compatible (Panasonic JU-475-5) or whether I am doing something wrong. I am new to this. Anthony RE: Apple /// System Disks - admin - 07-14-2019 Apple II disks require SPLICE mode, but it is very experimental for Apple II disks. There is a program called "a8rawconv" that will read/write Apple disks using the SuperCard Pro hardware directly (or with a .scp disk image). Commercially produced disks can almost always be duplicated using INDEX mode. Disks created with the C64 itself (formatted on a Commodore disk drive) have to be duplicated using SPLICE mode because there is no index pulse detector used in the Commodore drives. |
