Commodore PET 8250 Format - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Other disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=14) +---- Thread: Commodore PET 8250 Format (/showthread.php?tid=632) |
Commodore PET 8250 Format - abeckett - 07-14-2019 Hi there! Can I backup my Commodore PET 8250 format disks (eg Superpet 9000) using SCP? I'm not even sure if a HD 5.25" disk drive can read these properly! If so, what hardware do I select? Thanks! Anthony RE: Commodore PET 8250 Format - admin - 07-14-2019 The 8250 drives use a 100 TPI disk drive. If you have a 100 TPI disk drive plugged into the SCP then you could back the disks up. You would need to use the 1.2MB format. You can't use a standard 1.2MB (96 TPI) disk drive. |
