CBMSTUFF FORUM
Telnet translation - Printable Version
+--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79)
+--- Thread: Telnet translation (/showthread.php?tid=601)
Telnet translation - Montezuma - 02-01-2019
Hi,
I wondered which "TELNET Options" are supported by the WiModem232 firmware when TELNET translation is enabled (AT*T1).
For example in PUTTY telnet client source code:
https://git.tartarus.org/?p=simon/putty.git;a=blob;f=telnet.c;h=1287bd2dd6f31fe2aecfaf0244fa356e0558c439;hb=a5911f76d02b0de6fbc20b4c943ee33f54b432af
I found the following options:
Code:
NAWS, TSPEED, TTYPE, OENV, NENV, ECHO, SGA, BIN
Regards
M
RE: Telnet translation - admin - 02-01-2019
None of the Telnet commands are supported. Any time a Telnet command or request is sent to the WiModem(232) while using telnet translation mode (AT*T1), the WON'T/DON'T response is returned.
