Getting data off of ms-dos compatible disks - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: PC disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=11) +---- Thread: Getting data off of ms-dos compatible disks (/showthread.php?tid=573) |
Getting data off of ms-dos compatible disks - Stone - 09-05-2018 I have an interesting question: I don't necessarily need to make an image of an "ms-dos" disk- I just need to get data off of it. Is there a way to use the SCP to mount a 5.25" drive? If not, how can I mount/use an IBM disk image? (sorry if this is a very boneheaded question) RE: Getting data off of ms-dos compatible disks - admin - 09-05-2018 No, you can't mount SCP as a disk drive, but you can create a disk image and pull the files out of the image using the HxCFloppy Drive Emulator software. |
