CBMSTUFF FORUM
Unable to enter AT commands in CCGMS - Printable Version
+--- Forum: WiModem (https://www.cbmstuff.com/forum/forumdisplay.php?fid=75)
+---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=77)
+---- Thread: Unable to enter AT commands in CCGMS (/showthread.php?tid=496)
Unable to enter AT commands in CCGMS - chimera123 - 03-18-2018
Hello,
I was able to successfully connect my Wimodem to my wifi (Status: Ready). Afterwards I wanted to test the modem with CCGMS V6 incl. ZTERM but the problem is after starting the SW I am not able to enter any AT Commands --> Cursor is fixed, doesn´t move.
I tried to change from Graphics mode to ASCII no change - Also when I try to call a BBS with the F-Keys, nothing happens.
Somehow it looks to me that CCGMS/ZTERM does not recognize my modem.
Then I checked with Novaterm - with this SW I was able to send AT-Command - but I would really like to use CCGMS
Has anybody an idea what is wrong or what needs to be changed in CCGMS to make it work with Wimodem?
Thanks
Chimera
RE: Unable to enter AT commands in CCGMS - admin - 03-18-2018
Set your baud rate to whatever you are using in Novaterm. Smile
RE: Unable to enter AT commands in CCGMS - chimera123 - 03-19-2018
Hello,
Unbelievable....that fixed it Smile
Thank you so much for this suggestion
Chimera
