Can't connect to some BBSs - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: Can't connect to some BBSs (/showthread.php?tid=481) |
Can't connect to some BBSs - keepmalive - 02-20-2018 Hi. For some reason I can't connect to some BBSs. At first I just though they were down, but then I tried to connect using Putty on my Windows machine and they work fine. An example is Retro Battlestations BBS (bbs.fozztexx.com), I can't connect. After dialing, it says No Answer almost immediately. Any ideas? RE: Can't connect to some BBSs - admin - 02-20-2018 It could be that these require TELNET escaping enabled. Send the AT*T1 command and then try connecting. |
